Hi!
I work with the asp.net webgrid. I've a problem with special letter in grid after binding with load on demand.
for example: è = è on client side.
Do you know this problem ?
Mamat.
Hello Mamat,
You cna also try several other local encodings (the one that match your locale). In any case, also please contact Developer Support as suggested in the previous thread.
I've already try with UTF-8 with no better results...
Thanks for the answer.
Unfortunately no - nothing that I have seen recently, and it appears other people have not noticed this as well since noone posted for a few days. I guess in cases like this it is best to contact Developer Support directly, as this does not seem like something that can be easily resolved in public peer-to-peer community forums.
Developer Support can be reached via the following link:
http://es.infragistics.com/Support/#Overview
(just one suggestion that occurred to me while I was writing this post - can you double check your encoding and change it to UTF-8 and see if this fixes things?)
no ideas ?
