60
ultrawebgrid, Custom UserControl, UpdatePanel, LoadControl and Paging in an UserControl
Hello all,
i've got following constellation:
one default.aspx with two updatepanels (left, right of the form). on the left updatePanel, i've put the ultraweblistbar control. on the other updatepanel (right) i dynamically load the content in the item_clicked-event of the weblistbar via
control = LoadControl(...) and
updatepanelright.ContentTemplateContainer.Controls.Add(control)
updatepanelright.Update();
The loaded user control contains a sqldatasource and a ultrawebgrid.
The paging in the grid is activated and the event grid_pageIndexChanged is programmed as described in Infragistics help.
When starting the application and clicking on the weblistbar item, the grid is loaded and shown well, but when clicking on a pager link, nothing happens. Clicking a second time on the same pager link, the control disappears. I've noticed that even the grid_pageIndexChanged event is not fired. However, loading the user control into a placeholder control and not a updatePanel works fine with paging.
 Any Ideas ?
  • 28464
    Yes, testing with WARP would be a good idea and could lead to better results. I just want to add the this could very well be a page-lifecycle issue.  Controls added programmatically with code to template containers that need to fire events, must be added no later the OnInit I think so the listbar click event (fires after load) could be too late. It is a tricky topic that is very well described in the following blog post:
    http://msmvps.com/blogs/luisabreu/archive/2007/02/15/adding-controls-to-an-updatepanel-through-code.aspx
    With a lot of demo code and special comments on how to deal with postbacks and events. Highly recommended - can help a lot.
    HTH,
  • 1763
    Have you tried using a WebAsyncRefreshPanel instead of the UpdatePanel? I'm not sure, but I remember reading through this forum that the WebGrid does not work well when it's inside an update panel, but it does allrightewhen using the WARP.
