v14.2.20142.2477
We are at the tail end of development on a project and doing a last minute sweep on memory and CPU utilization in IE 11 and I noticed two things:
Infragistics.ui.editors.js is calling the following methods endlessly:
_doTimer and _fixHeight
jquery-2.1.3.js is calling the following method endlessly:
proxy = function () {
return fn.apply( context || this, args.concat ( slice.call( arguments) ) );
Reason why I bring it up here is because the editors are from the igGrid and an empty igGrid object is being passed into the proxy call as arguments.
It is a small find but it does cause the CPU utilization to hover near 5-10% while the UI is doing absolutely nothing. Thoughts on why it is behaving in this manner?
Hello Karthik,
If you need further assistance regarding this matter, please let me know.
Tsanna
Yep this solved it!
Thanks!
This is caused by a functionality in igGrid which resizes itself when its container is resized.
You can disable this functionality by setting ‘enableResizeContainerCheck’ option to false: http://help.infragistics.com/jQuery/2015.1/ui.iggrid#options:enableResizeContainerCheck Please try this and let me know if the problem still persists after that.
