205
Add custom CSS class to ui-igstartupbrowsebutton
Im using the igUpload on a responsive site together with fastclick (https://github.com/ftlabs/fastclick) to eliminate the 300ms delay between a physical tap and the firing of a click event on mobile browsers.
The problem is that it wont work correctly with igstartupbrowsebutton. The click event is never fired correctly on iOs.
Im rendering the upload with
    $.ig.loader('igUpload', function() {
        $('#projectImage').igUpload({
            mode: 'multiple',
            css: {
                "what_name_should_i_use_here": "needsclick" // Does not work
            multipleFiles: true,
            maxSimultaneousFilesUploads: 1,
            maxUploadedFiles: 50,
            autostartupload: true,
            labelUploadButton: 'Submit photos',
            controlId: 'projectImage',
            progressUrl: '/IGUploadStatusHandler.ashx',
allowedExtensions: [ 'jpg', 'JPG', 'jpeg', 'JPEG' ]
<button id="projectImage_ibb" class="ui-igstartupbrowsebutton ui-button-text-only ui-button ui-igbutton ui-widget ui-widget-content ui-corner-all ui-state-default" title="Upload File" role="button" aria-disabled="false"><span class="ui-button-text" id="projectImage_ibb_lbl"><span class="glyphicon glyphicon-upload"></span> Submit photos</span></button>
The problem is that i need to add a custom class to browsebutton to prevent FastClick on the specific element. Eg:
<button id="projectImage_ibb" class="ui-igstartupbrowsebutton ui-button-text-only ui-button ui-igbutton ui-widget ui-widget-content ui-corner-all ui-state-default needsclick" title="Upload File" role="button" aria-disabled="false"><span class="ui-button-text" id="projectImage_ibb_lbl"><span class="glyphicon glyphicon-upload"></span> Submit photos</span></button>
