hello,
I have the following splitter and have two issues:
$("#splitter").igSplitter({ height: "610px", orientation: 'vertical', panels: [ { collapsible: true, size: "50%" }, { collapsible: true, size: "30%" } ] });
1) I can't seem to change the default "white" color of the splitter, so I wrapped a <div> around it with my own color. Except that if I collapse the right panel, the splitter color defaults back to white. It also goes to white if I resize my browser window (left to right, or right to left).
2) I often lose the collapse/expand icon when collapsing the right panel. if I then widen my browser window, the icon shows up ! Then of course my right panel goes white again !
Is some styling that someone can guide me through to override the default WHITE in the panels ?
Does the fact that I'm putting the splitter INSIDE an igLayout div have something to do with this ?
For example, here's an outline of my markup
<div id="layout" style="width:100%; height: 620px;"> <div class="left"> SOME TEXT HERE </div> <div class="right"> SOME TEXT HERE </div> <div class="header" >Razor Configuration</div> <div class="footer" >Razor Configuration</div>
<div class="center"> <div id="splitter"> <div class="panel1" > <!-- add a div here to get control of the color -->
<!-- A BUNCH OF HTML ELEMENTS HERE... -->
</div>
thank you.
Bob
Hello Bob M.
Did you accomplish that scenario? Do you need a help?
Stanimir Todorov
Okay, sure Stanimir.
Please visit http://www.bobmazzo.com/temp/ and you'll see Margins_copy.cshtml.
thanks !
Perhaps, there are some CSS rules that might break the layout.
Would you send me a link to the app in order to debug it? Or sample with that.
Stanimir
Hi again,
I'm sorry to keep bothering you.
So I have the css code as you suggested, but I still lose the Splitter Icon sometimes:
.ui-igsplitter .ui-widget-content { background-color: #c7d1d6; } .ui-igsplitter {position: relative;}
I think the igLayoutManager is also skewing my page a bit. Look at the horizontal scroll bar at the bottom.
I wonder why what's happening. As if the layout manager is automatically widening the whole page for some reason. I would need more control over that.
See screen shot below of 1) the magical disappearing splitter icon, 2) the very wide page with scroll bar.
I can't figure out how to attach an image to this post, so I put it up on my personal website (not a virus):
www.bobmazzo.com/temp/splitter_stuff.jpg
thanks a million !
Yes the problem comes from layout manager.
Add this to fix disappearing of the splitter button:
.ui-igsplitter { position: relative; }
And that will fix the problem with color when collapsing/expaning:
.ui-widget-content { background-color: #c7d1d6!important; }
