110
Binding igHierarchicalGrid after initial binding not working.
I'm trying to use a search component to populate the hierarchical grid with json data. The issue I'm running into is that the grid is initialized on screen load and the datasource is set to a json object that is empty i.e "var datasource = [];" When I then get data via an ajax call and try to update the datasource object with the data returned from the ajax call and rebind my grid "$("#myHierarchicalGrid").igHierarchicalGrid("dataBind");" nothing happens.
Is there a way to initialize the hierarchical grid initially to an empty json object and rebind it with a json object at a later point in time? I also tried to do something like the following code snippet, but because the grid's initial datasource was empty it doesn't return any child table elements for me to bind to.
$('#hierarchicalGrid').igHierarchicalGrid('allChildrenWidgets')[0].dataSourceObject(jsonObject);
Any help would be greatly appreciated!!!
