25
The resource cannot be found
I have added a infragistics upload control to my view but I can't seem to get it to work. I followed the help and did all I can think off. I might have missed something easy, I don't know.
What happens is that when I open the partialview that contains the upload control, this all works. When I click the upload button I choose a file, in this case a jpg. I press OK and then I get the errors: The controller for path '/Documents/ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx' could not be found
And I also get the following javascript errors:
The resource cannot be found.
Requested URL: /Documents/ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx
Requested URL: /IGUploadStatusHandler.ashx
I have a _layout.cshtml class that contains all necessary references,
I've adjusted my Web.Config
Code:
<appSettings>
<add key="fileUploadPath" value="~/Uploads" />
<add key="maxFileSizeLimit" value="100000000" />
</appSettings>
<httpHandlers>
<add verb="GET" type="Infragistics.Web.Mvc.UploadStatusHandler" path="IGUploadStatusHandler.ashx" />
</httpHandlers>
<httpModules>
<add name="IGUploadModule" type="Infragistics.Web.Mvc.UploadModule" />
</httpModules>
The code in my partialview:
@(Html.Infragistics().Upload()
.ID("igUpload1")
.AutoStartUpload(true)
.Mode(UploadMode.Single)
.FileSizeMetric(UploadSizeMetric.MBytes)
.Width("500")
.LabelSummaryTemplate("Status: {0} out of {1} uploaded. ")
.ProgressUrl("/IGUploadStatusHandler.ashx")
.Render())
And in Global.asax.cs
public static void RegisterRoutes(RouteCollection routes)
routes.IgnoreRoute("IGUploadStatusHandler.ashx");
Any Ideas? Did I forget something, I'm guessing I still need to add some jquery in my partialview but I have no idea what exactly, I'm fairly new to all this.
I hope you can help
Greetings Ben
