185
igUpload in jquery dialog does not work
Hello. I´m using infragistics.web.mvc version 3.12.1.2023
I can´t do igupload to work on jquery dialog.
I have a partialview that is displayed on a jquery dialog. When I tried to upload a file, I see on fiddler  this lines:
404 HTTP mainserverv /ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx?key=uRiq1OekDRoHIfFPX5zQBHl59uNZF8&cid=
404 HTTP mainserverv /IGUploadStatusHandler.ashx?key=uRiq1OekDRoHIfFPX5zQBHl59uNZF8&command=status&_=1345839304371
but when I use igUpload on a normal page,works correctly and I see this lines on fiddler:
200 HTTP mainserverv /Boletas/Empresa/ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx?key=T3UlKF6Q55z6ccpH85RnFAkpntaR0z&cid= 13
200 HTTP mainserverv /Boletas/IGUploadStatusHandler.ashx?key=T3UlKF6Q55z6ccpH85RnFAkpntaR0z&command=status&_=1345839485560
When I use igupload on jquery Dialog the URL is not correct.
I set IgUpload on this way:
@(Html.Infragistics().Upload()
.ID("igUpload")
.AllowedExtensions(new List<string> { "txt", "xls", "xlsx" })
.AutoStartUpload(true)
.Mode(UploadMode.Single)
.LabelUploadButton("Upload")
.LabelAddButton("Add")
.FileSizeMetric(UploadSizeMetric.Auto)
.Width("350")
.LabelSummaryTemplate("Status: {0} out of {1} uploaded. ")
.Render()
In global.asax :
routes.IgnoreRoute("IGUploadStatusHandler.ashx");
in Web.config:
<httpHandlers>
<add verb="GET" type="Infragistics.Web.Mvc.UploadStatusHandler" path="IGUploadStatusHandler.ashx" />
</httpHandlers>
<httpModules>
<add name="IGUploadModule" type="Infragistics.Web.Mvc.UploadModule" />
</httpModules>
thanks in advance
  • 185
    Verified Answer
    Hello. The error was not related to the window jquery. It was the URL. If I use the component from a URL that is not terminated with '/' does not work.
