If I delete a row and commit the changes, the datasource of the grid has 1 row less, but if I delete two rows and commit the changes , only 1 row is deleted
I´m using infragistics.Web.Mvc version 3.12.1.2023
My grid :
@( Html.Infragistics().Grid<BoletaDetalleView>() .ID("igGrid") .Columns(column => {
column.For(x => x.ApellidoNombre).DataType("string").HeaderText("Apellido Nombre").Width("50%"); column.For(x => x.CUIL).DataType("int").HeaderText("CUIL").Width("20%"); column.For(x => x.MotivoBajaDescripcion).HeaderText("Motivo Baja").Width("20%"); column.For(x => x.Remuneracion).DataType("number").HeaderText("Remuneracion").Width("10%"); column.For(x => x.AfiliadoId).DataType("int").Hidden(true); column.For(x => x.PersonalId).DataType("int").Hidden(true); column.For(x => x.BoletaId).DataType("int").Hidden(true); column.For(x => x.MotivoBajaId).DataType("int").Hidden(true); column.For(x => x.ID).DataType("int").HeaderText("ID").Hidden(true);
}) .Features(features => { features.Sorting().Mode(SortingMode.Single).ColumnSettings(settings => { settings.ColumnSetting().ColumnKey("ID").AllowSorting(true);
}); features.Selection().MouseDragSelect(true).MultipleSelection(false).Mode(SelectionMode.Row); features.Updating().EditMode(GridEditMode.Row).EnableAddRow(true).EnableDeleteRow(true);
.ClientDataSourceType(ClientDataSourceType.JSON) .DataSource(new List<BoletaDetalleView>().AsQueryable()) .Width("100%") .AutoCommit(false) .DataBind() .Render() )
I have a "Save" button. When I click my save button the changes in the igGrid, the dataSource must be sent to my action. this code es executed on save click:
$(function () { $("#btnSave").click(function () { $("#igGrid").igGrid("commit");
var dataSource = $("#igGrid").data("igGrid").dataSource.data();
$.ajax( { type: 'POST', url: "Boleta/Save", data: JSON.stringify({ model: modelObject, data: dataSource }), contentType: "application/json, charset=utf-8", dataType: "json" });
Hi,In order to work correctly igGridUpdating requires primary key to be defined.In your sample you didn't define primary key. Look at the JavaScript console. If you see message like this one:"In order to support update operations after a row was deleted, application should define "primaryKey" in options of igGrid." then this is your problem.
Hope this helps,Martin PavlovInfragistics, Inc.
