Hi, In our application Many IgGrids are used. But we want maintain and Controlled some of IgGrid Properties From Centralized place.
For Example :
Vartualization property Should be true for all the developed grids. If any one is Creating new grid this property should be True.
Like some of the other properties too should be controlled.
AutoGenerateColumns, VirtualizationMode.
Is there any way to handle this or any workaround.
We are creating grids in the Razor view like below
@(Html.Infragistics().Grid<DataViewModel> () .AutoGenerateColumns(false) .ID("tmeGrid").Width("100%") .Height("400px") .Virtualization(true) .VirtualizationMode(VirtualizationMode.Continuous) .PrimaryKey("Id") .AlternateRowStyles(true).EnableHoverStyles(true) .Columns(col => {col.For(x => x.Id).HeaderText("Number").DataType("number").Width("6%").Template("<td actionRootId=${Id} actionTypeId='2' Class='contextCss'>${Id}</td>").GetType();
col.For(x => x.Owner).HeaderText("Owner").Width("10%").Template("<td actionRootId=${Id} actionTypeId='2' class='contextCss'>${Owner}</td>");
col.For(x => x.StatusFormatted).HeaderText("Status").Width("6%").Template("<td actionRootId=${Id} actionTypeId='2' class='contextCss'>${StatusFormatted}</td>");
}) .Features( features => { features.Sorting().Type(OpType.Remote).Mode(SortingMode.Single); features.Filtering().Type(OpType.Remote).FilterSummaryAlwaysVisible(false).ShowNullConditions(true).CaseSensitive(false).ShowEmptyConditions(true).Mode(FilterMode.Simple).GetType(); features.Tooltips().Visibility(TooltipsVisibility.Overflow); features.Selection().Mode(SelectionMode.Row).SkipChildren(true); features.Resizing(); features.Paging().Type(OpType.Remote).PageSizeList(Model.PaginationConfig.PageSizeOptions).PageSize(Model.PaginationConfig.DefaultPageSize).RecordCountKey("recordCountKey").PageSizeUrlKey("pageSize").PageIndexUrlKey("pageNo").ShowPageSizeDropDown(true).PageSizeDropDownLocation("inpager"); }) .DataSourceUrl(Url.Action("GetItemsData", "View", new { Id = Model.Id})) .ResponseDataKey("dataList").DataBind() .Render() )
Hello Ram p,
A possible approach would be to override the igGrid object's prototype on the client side – this would allow you to set default values to the options you mentioned. These options would apply for every igGrid that gets initialized afterwards. There are two important things to note here:
Here is a snippet from a sample View file so that you get a better idea of where to override the igGrid prototype:
<!DOCTYPE html> <html> <head> <meta name="viewport" content="width=device-width" /> <title>Index</title> <script src="http://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script> <script src="http://code.jquery.com/jquery-1.11.3.min.js"></script> <script src="http://code.jquery.com/ui/1.11.1/jquery-ui.min.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2018.1/latest/js/infragistics.core.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2018.1/latest/js/infragistics.lob.js"></script> <link href="http://cdn-na.infragistics.com/igniteui/2018.1/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" /> <link href="http://cdn-na.infragistics.com/igniteui/2018.1/latest/css/structure/infragistics.css" rel="stylesheet" /> <script> $.ui.igGrid.prototype.options.autoCommit = true; $.ui.igGrid.prototype.options.virtualization = true; $.ui.igGrid.prototype.options.virtualizationMode = "continuous"; </script> </head> <body> <div> @(Html.Infragistics() .Grid(Model) .ID("grid") .Width("100%") .Height("600px") .PrimaryKey("ProductID") .AutoGenerateColumns(false) .Columns(column => { column.For(x => x.ProductID).HeaderText("Id").Width("20%"); column.For(x => x.ProductName).HeaderText("Name").Width("50%"); column.For(x => x.StartDate).HeaderText("Date").DataType("date").Width("30%"); }) .Features(features => { features.Paging().PageSize(10).Type(OpType.Remote).RecordCountKey("TotalRecordsCount"); features.Filtering().Type(OpType.Remote).Mode(FilterMode.Simple); features.Sorting().Type(OpType.Remote).SortUrlAscValueKey("asc").SortUrlKeyDescValue("desc").SortUrlKey("orderby"); features.GroupBy().Type(OpType.Remote).GroupByUrlKeyAscValue("asc").GroupByUrlKeyDescValue("desc").GroupByUrlKey("groupBy"); features.Updating().ColumnSettings(cs => { cs.ColumnSetting().ColumnKey("StartDate").EditorType(ColumnEditorType.DatePicker).Required(true).EditorOptions("datepickerOptions: {changeYear: true, changeMonth: true}"); }); }) .DataSourceUrl(Url.Action("GetData1")) .ResponseDataKey("Records") .Render() ) </div> </body> </html>
If you need any additional assistance, feel free to contact me.
