I am binding to a custom data source which I am converting to Json in MVC. Based on the value of "RealizedRatePerHour", I want to adjust the size of the marker shown on the map. I can't find anything showing how this can be done
@model IEnumerable<OpsOverallGeoMapViewModel>
<style> #tooltipTable { font-family: Verdana, Arial, Helvetica, sans-serif; width: 100%; border-collapse: collapse; }
#tooltipTable td, #tooltipTable th { font-size: 9px; border: 1px solid #28b51c; padding: 3px 7px 2px 7px; }
#tooltipTable th { font-weight: bold; font-size: 11px; text-align: left; padding-top: 5px; padding-bottom: 4px; background-color: #28b51c; color: #ffffff; }</style><script id="tooltipTemplate" type="text/x-jquery-tmpl"> <table id="tooltipTable"> <tr><th class="tooltipHeading" colspan="2">${item.Country}</th></tr> <tr> <td>Total Hours:</td> <td>${item.Hours}</td> </tr> <tr> <td>Total Billing:</td> <td>${item.Billing}</td> </tr> <tr> <td>Realized Rate Per Hour:</td> <td>${item.RealizedRatePerHour}</td> </tr> </table></script>
<div id="map"></div>
<script>
$(function () {
var model = @Html.Raw(Json.Encode(Model));
$("#map").igMap({ width: "700px", height: "500px", windowRect: { left: 0.225, top: 0.1, height: 0.6, width: 0.6 }, series: [{ type: "geographicSymbol", name: "worldCities", dataSource: model, //JSON Array defined above latitudeMemberPath: "Latitude", longitudeMemberPath: "Longitude", markerType: "automatic", markerOutline: "#28b51c", markerBrush: "#28b51c", showTooltip: true, tooltipTemplate: "tooltipTemplate"
}); }); </script>
Thank you for contacting us.
As I see you are using marker template in order to display it on the map, and you want to change some measures of the marker. You can have a look at the markerTemplate rendering function. I hope that this will help you to achieve your requirements. Below you will find online sample that is showing exactly this:
http://igniteui.com/map/marker-template
