30
Set Window dynamically when view changes in charting
Consider the below chart which represents the plotting of the data for all the data points present.
But once we zoom into the chart it seems to be a straight line because the scale does not change when the the view changes.
Is it possible to adjust the chart maximum and minimum axis value dynamically when we change the view of the window?
  • 34810
    Hello Sandeep,
    I have been investigating into the behavior you are seeing, and I am curious if you are setting both of the isVerticalZoomEnabled and isHorizontalZoomEnabled properties on the IgxFinancialChart to “true”? If I set the yAxisMode to “PercentChange”, which it appears that you are doing and then set these properties, the values are being adjusted correctly when zooming on my end.
    Can you please test the above on your end to see if it resolves the issue?
